I have an RTK surveyor connected to SW Maps (also have tried Lefebure Client) through Bluetooth on an android, and a base station that is basically a replica of the DIY GNSS Reference Station tutorial on Sparkfun, outputting its RTCM data to an NTRIP server on rtk2go.com.
SW Maps and Lefebure are both able to connect to the rover over BT and both seem to be receiving data from the NTRIP server. The server does have my base station RTCM data as well. However, when I go to “GNSS Status” on SW Maps, the rover does not seem to be applying the RTK fix or outputting any data to that screen. The Lefebure NTRIP client does a similar thing- connects to both Bluetooth, then says “Waiting for GGA from Receiver”, with no further successes in applying a fix to the rover.
I’ve tried resetting the rover’s settings to factory, but it does not make a difference. Screenshots are attached. I think I’m probably missing something very basic in the set-up, but I’ve gone over it multiple times to make sure everything is right and it does not work.
