Rtk
Need a full solution. Rover and base station. Need the base station to be on the ground using some kind of tripod or telescope.
Need a rover that I can walk around and grab measurements with at certain locations.
What could I buy that would help with my setup
We have a lot of options, let’s narrow it down a bit:
What kind of accuracy do you require? Do you have a specific update rate required? Will there be cell service where you’ll be using them?
We want to be very accurate cm accuracy. We won’t be using a cell tower.
Update rate doesn’t matter
Hi any updates on this haven’t heard anything
For places without access to an internet connection/cell service we recommend a PPP service like PointPerfect Flex | u-blox (if your area has coverage! See PointPerfect Flex service coverage | u-blox)
In this case if 3-6cm accuracy suffices you’ll just need a u-blox RTK module (rover) + a subscription and a clear view of the sky (acts as base)
Is your area covered?
