Hello all,
I am trying to setup the SAM9-L9260 development board with Keil compiler IDE and RTX-ARM library.
I am using the evaluation Keil uVison3 as a compiler, and "JLINK/Jtag debbugger (from Segger).
I use a startup sample program from Keil, made for the ATMEL AT91SAM9260-EK board.
I am not able to download and RUN/Debbug the test program on SAM-L9260.
I believe that there are differences between the memory mapping and/or memory setup between the two ARM boards. Or also there is a missing/bad memory configuration.
Could anyone please help me to find this information or a sample uVision projet for SAM-L9260 (whith external memory setup-configurations)?
Thanks in advance.
mRomano
