Shifted:
USB_H = USB Host, that means a flash drive or other thing that the board hosts, you really can’t connect a host to a host.
USB_D = USB Device, where it acts like a USB device when plugged into a USB host.
Neither port will supply or power the board.
I did supply the 5VDC external voltage and the system is booting but a lot of error display on the Hyperterminal when I push the reset button
Please see below
3V 8-bit)CRC faile
512 MiBc3c098.
In: serialtes from 0x5c
Out: seriald ECC errorRC
Err: serialc26c10.d_in
PHY not reset!!52,52525252}JFF
Hit any key to stop autoboot: 0ead(0x518 bytes from 0x5c3bae8)
NAND read: device 0 offset 0x100000, size 0x1a2828(583) jffs2_do_read_in
JFFS2 notice: (583) jffs2_g
1714216 bytes read: OKder CRC failed at 0x5c3
Booting image at 21500000 …ad_inode_internal: no data nodes
Image Name: Linux-2.6.23,52525252,52525252}ess… (58
Image Type: ARM Linux Kernel Image (uncompressed)inode_internal: no data nodes found for ino #adness…
Data Size: 1714152 Bytes = 1.6 MByte
Returned error
JFFS2 noti
Load Address: 20008000eck of ino #16475. ,52525
Entry Point: 2
Returned error for crccheck of i
… done, booting the kernel.tice: (583) jffs2_get_inode_nodes: Node header CRC failed at 0x5c3d188. fai
Linux version 2.6.23 (ivan@debian.l123.org) (gcc version 4.1.2) #5 PREEMPT Sun O,5252,52525252,52525252}52,52525252,52525252}_read_in
mtd->read(0x170 bytes from
ct 14 02:01:51 EEST 2007errorinode_internal: no
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=000531772_get_inode_nodes: Node header CRC failed at 0x5c3ce90.
Retur
Machine: Olimex SAM9-L9260no #16424. Expect badness.
Memory policy: ECC disabled, Data cache writeback ECC errorRC
JFFS2 notice: (5
JFFS2 notice: (583)
Clocks: CPU 180 MHz, master 90 MHz, main 18.432 MHz5_nodes: Node header70,70707070,70707070}
Kernel command line: mem=64M console=ttyS0,115200, noinitrd root=/dev/mtdblock1,
{5252,5252,52525252,52525252}_inode_nodes: Node header CRC
mtd->read(0xc8 byt
rootfstype=jffs2) returned ECC e
AT91: 96 gpio irqs in 3 banks jffs2_get_inode_n
{5252,5252
PID hash table entries: 256 (order: 8, 1024 bytes)ader CRC failed at 0x5c40f38. crccheck of ino #164
Console: colour dummy device 80x30: (583) jffs2_get_inode
{dada,dada
console [ttyS0] enablede: (583) jffs2_get_inod
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)ail
{7070,7070,70707070,70707070}
Returne
Generic PHY: Registered new driver_n
{5252,5252,52525252,52525252}rn
SCSI subsystem initialized
mtd->read(0x6d4 bytes fro
usbcore: registered new interface driver usbfs,52525252,52525252}or crccheck of ino #1
JFFS2
usbcore: registered new interface driver hubader CRC failed at 0x5c3f92c…r ino # notic
usbcore: registered new device driver usbr CRC
JFFS2 notice: (5
{5252,5252,5252525
NET: Registered protocol family 20x5c31
mtd->read(0x5d0 bytes from
io scheduler deadline registeredode_nodes: Node header CRC faile
io scheduler cfq registered (default)ternal: no data nodes found for ino #
atmel_usart.0: ttyS0 at MMIO 0xfefff200 (irq = 1) is a ATMEL_SERIAL_nodes: No
mtd->read(0x150 bytes from 0x5c3d6b0) returned ECC error
atmel_usart.1: ttyS1 at MMIO 0xfffb0000 (irq = 6) is a ATMEL_SERIALe: (583) jffs2_get_inode_nodes: Node header CRC failed at 0x5c3d6b0
atmel_usart.2: ttyS2 at MMIO 0xfffb4000 (irq = 7) is a ATMEL_SERIAL2_do_read_in
{5252,5252,52525252,52525252}tice: (583) jffs2_get_ino
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksizefound for ino #nodes found for ino #) jffs2_get_inode_n
{5252,5252,52
loop: module loaded5c2236
16477r CRC
R
MACB_mii_bus: probedcheck of ino #16477.
eth0: no PHY found data nodes found
block2mtd: version $Revision: 1.30 $252,
mtd->read(0x628 bytes from 0x5c
NAND device: Manufacturer ID: 0xec, Chip ID: 0xdc (Samsung NAND 512MiB 3,3Vt bad
Bad eraseblock 3 at 0x00060000des found for ino #2,52525252}
Bad eraseblock 8 at 0x00100000FFS2 warning: (583) jffs2_do_r
Bad eraseblock 9 at 0x00120000ror for crccheck of ino #16478
Bad eraseblock 10 at 0x0014000052525252,52525252}es: Node
{525
Bad eraseblock 11 at 0x00160000583) jffs2_get_inode_nodes: Nod
Bad eraseblock 12 at 0x00180000. jffs2_do_read_inode_internal:
Bad eraseblock 13 at 0x001a0000jffs2_get_inode_n
{5252,5252,52
Bad eraseblock 14 at 0x001c0000no #16134. Ex
JFFS2 warning: (5
Bad eraseblock 15 at 0x001e0000: no data nodes found for ino #
Bad eraseblock 16 at 0x00200000odes: No
JFFS2 warning: (583) j
Bad eraseblock 17 at 0x00220000urned error for crccheck of ino
Bad eraseblock 18 at 0x002400002,5252,52525252,52525252}
Bad eraseblock 34 at 0x00440000arning: (583) jffs2_do_read_ino
Bad eraseblock 35 at 0x00460000crccheck of ino #16480. Expect
Bad eraseblock 36 at 0x0048000052525252}83) jf
{5252,525
163
Bad eraseblock 37 at 0x004a0000om 0x5c448d4) returned ECC erro
Bad eraseblock 38 at 0x004c0000o_read_inode_internal: no
JFFS2
Bad eraseblock 39 at 0x004e0000odes: Node header CRC failed at
Bad eraseblock 40 at 0x00500000. Ex
JFFS2 warning: (583) jffs2
Bad eraseblock 41 at 0x005200002,5252,52525252,52525252}t 0x5c
Bad eraseblock 42 at 0x00540000d(0x724 bytes from 0x5c440dc) r
Bad eraseblock 43 at 0x00560000or for crccheck of ino #16436.
Bad eraseblock 44 at 0x00580000
Bad eraseblock 50 at 0x00640000583) jffs2_get_inode_nodes: Nod
Bad eraseblock 51 at 0x00660000.#ccheck of ino #16382. Expect
Bad eraseblock 52 at 0x0068000052525252}83) jffs
{5252,5252,52
Bad eraseblock 53 at 0x006a0000no #16437. Ex
mtd->read(0x44 by
Bad eraseblock 54 at 0x006c0000 errorCRC failed at 0x5bf
JFFS2
Bad eraseblock 55 at 0x006e0000FFS2 notice: (583) jffs2_get_in
Bad eraseblock 56 at 0x00700000d at 0x5c42fbc.ing: (583) jffs2
Bad eraseblock 57 at 0x007200002,5252,52525252,52525252}tice:
Bad eraseblock 58 at 0x00740000rning: (583) jffs2_do_read_
JFF
Bad eraseblock 59 at 0x00760000_nodes: Node header CRC failed
Bad eraseblock 60 at 0x00780000
1643
{5252,5252,525252
0x00000000-0x00a00000 : "Bootloader Area"52,52525252,52525252}jffs2_do_read_inode_
0x00a00000-0x20000000 : “User Area” 0x5c418d0) returned ECC errors…o
at91_ohci at91_ohci: AT91 OHCIc4.eade
162602
16
JFFS2 not
at91_ohci at91_ohci: new USB bus registered, assigned bus number 1d0.5c27f48.252}no #16082. Expect badness…2
JFFS2 n
JFFS2 notice:
at91_ohci at91_ohci: irq 20, io mem 0x00500000ailed at 0x5c32318.x5c093f8)
JFFS2 warning: (5
usb usb1: configuration #1 chosen from 1 choicefound for ino #,52525252,52525252}eck of ino #1
hub 1-0:1.0: USB hub founding: (583) jffs2_do_r
1648
hub 1-0:1.0: 2 ports detectedheck of ino #16481. Expect ba
Initializing USB Mass Storage driver…
{5252,525
163225
16
NET: Registered protocol family 153) jffs2_get_inode_nodes: Node hea
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)98cc)
JFFS2 notice: (583) jffs2_get_inode_nodes: No
{52
Empty flash at 0x06dcf970 ends at 0x06dd0000#16201. Ex
JFFS2 warning: (583) jffs2_do_rea
Empty flash at 0x06f010b4 ends at 0x06f01800 # found for ino #ccheck of ino #1
JFFS2 war
Empty flash at 0x072930dc ends at 0x07293800data
Returned error for crccheck of ino #164
Empty flash at 0x0874aa08 ends at 0x0874b000ailed at 0x5c235b
16387r CRC
Returne
mtd->re
Empty flash at 0x08ae216c ends at 0x08ae2800roreturned ECC error,52525252,52525252}eck o
Empty flash at 0x0b025b5c ends at 0x0b026000inode_nodes: Node header CRC failed at 0x5c4
Empty flash at 0x0c0758c4 ends at 0x0c076000
{5
Empty flash at 0x122c3940 ends at 0x122c4000_do_read_in
Empty flash at 0x14c90960 ends at 0x14c91000o #2,52525252}160.5c12c04.ta nodes found fo
Empty flash at 0x188720c0 ends at 0x18872800no #1
Empty flash at 0x189efcd4 ends at 0x189f0000JFFS2 notice: (583) jffs2_get_inode_n
mtd->r
Empty flash at 0x1b1c10dc ends at 0x1b1c1800errors…b
VFS: Mounted root (jffs2 filesystem).ode_internal: no data nodes found for
Freeing init memory: 108K{5252,5252,52525252,52525
INIT: version 2.86 booting3) jff
JFFS2 warning: (583
Starting the hotplug events dispatcher: udevd.ound for ino #r for crccheck of ino #16329. Ex
Synthesizing the initial hotplug events…done.
16486ode_n
Waiting for /dev to be fully populated…end
16206
JFFS2 notice: (5
end_request: I/O error, dev mtdblock0, sector 0d at 0x5c46700. jffs2_do_read_inode_internal: n
Buffer I/O error on device mtdblock0, logical block 05252,52525252,52525252}ode_internal: no data nodes f
end_request: I/O error, dev mtdblock0, sector 0l: no data nodes found for ino #2,52525252}2,
1
Buffer I/O error on device mtdblock0, logical block 0583) jffs2_
16488ode_n
end_request: I/O error, dev mtdblock0, sector rom 0x5c2b20
16208
end_request: I/O error, dev mtdblock0, sector 0ffs2_get_inode_nodes: Node header CRC failed at
end_request: I/O error, dev mtdblock0, sector 0) jffs2_do_read_inode_internal: no data no
{525
end_request: I/O error, dev mtdblock0, sector 0es: No
JFFS2 warning: (583) jffs2_do_read_inode
end_request: I/O error, dev mtdblock0, sector 06452. Expect badness…n
end_request: I/O error, dev mtdblock0, sector 0ror for crccheck of ino #16491. Expect badness.
end_request: I/O error, dev mtdblock0, sector 0al: no data no
end_request: I/O error, dev mtdblock0, sector 0f ino #16153. Ex
end_request: I/O error, dev mtdblock0, sector 0252,52525252}83) jffs2_get_inode_nodes: No
JFFS
end_request: I/O error, dev mtdblock0, sector 0o data nodes found for ino #f ino #16453. Expec
16492
JFFS2 not
end_request: I/O error, dev mtdblock0, sector 0ror for crccheck of ino #16493. Expect badness.
JFFS2 n
done.des:
Activating swap…done.t 0x5c46e30.o_read_inod
Checking root file system…fsck 1.40-WIP (14-Nov-2006): no data no
{5252,5252,52525252,52525252}83) jffs2_get
fsck: fsck.jffs2: not foundng: (583) jffs2_do_read_ino
fsck: Error 2 while executing fsck.jffs2 for /dev/mtdblock1ct badness…rase at 0x08ba
done.494
Cleaning up ifupdown…95s: No
Returned error f
Loading device-mapper support.ct badness…ailed at 0x5c3364
Checking file systems…fsck 1.40-WIP (14-Nov-2006)tice: (583) check_node_data: wrong data CRC in data
done.at 0x
Setting kernel variables…done.warning: (583) jffs2_do_read_ino
Mounting local filesystems…done.5ecc, calculated 0xe59a27c6.e_node
Activating swapfile swap…done.
JFFS2 notice: (583) check_node_
Setting up networking…ta node at 0x06f00f8ect b
Configuring network interfaces…SIO34}
16100
16
JFFS2 notice: (858) check_node_data: wrong data CRC in data node at 0x122c35d4: jffs2_do_read_in
Erase at 0x059a0000 failed immediately: errno -5om 0x5c338d8)
read 0x4dd27854, calculated 0xc86763c1. of newly-erased block at 0x05980000 fa
JFFS2 notice: (858) check_node_data: wrong data CRC in data node at 0x189ef750:2_get_inode_nodes: Node
cannot write OOB for EB at 05980000, requested 12 bytes
read 0x214e861c, calculated 0x66510cc3.ect badness…o
JFFS2 notice: (858) check_node_data: wrong data CRC in data node at 0x0cb98620:ernal: no data
Erase at 0x05960000 failed immedia
Starting portmap daemon…Already running..
Starting MTA: exim4.
Starting internet superserver: inetd.
Starting OpenBSD Secure Shell server: sshd.
Starting NFS common utilities: statd.
Starting deferred execution scheduler: atdStarting periodic command scheduler: c
rond.
Debian GNU/Linux 4.0 sam9-l9260 ttyS0
sam9-l9260 login:
sam9-l9260 login: JFFS2 notice: (582) check_node_data: wrong data CRC in data no
de at 0x0b025458: read 0xa0fea613, calculated 0xf771f508.
JFFS2 notice: (582) check_node_data: wrong data CRC in data node at 0x1b1c0fa8:
read 0x6e955ecc, calculated 0xe59a27c6.
JFFS2 notice: (582) check_node_data: wrong data CRC in data node at 0x06f00f80:
read 0x6e955ecc, calculated 0x482eecdf.
JFFS2 notice: (582) check_node_data: wrong data CRC in data node at 0x06dcf138:
read 0x951e336d, calculated 0xe1acb4eb.
JFFS2 notice: (582) check_node_data: wrong data CRC in data node at 0x10aa0000:
read 0x71334ede, calculated 0x37bc15e7.
And according to the SAM9-L9260 User Manual Page 20 that described about the Restore the default boot loader and kernel.
When connect the USB cable (USB_D port), the window detected the SAM9-L9260 board, but the windows cannot install the hardware driver.
(I did insert the CD and also re-installed the AT91-ISP v1.12 but did not help).
So, I did change the connection to Com1, the BAT file as below:
sam-ba.exe COM1 AT91SAM9260-EK AT91SAM9260_demo_linux_NandFlash.tcl ./ u-boot-env-nf.bin > logfile.log
notepad logfile.log
When I run the BAT file, the log shown as below:
-I- Waiting …
connection : COM1
board : AT91SAM9260-EK
target(handle) : 19215472
read chip ID : 0x20084E08 at addr: 0xFFFFEE40
read chip ID : 0x46467708 at addr: 0xFFFFF240
read chip ID : 0x45454646 at addr: 0xFFFFF240
read chip ID : 0x342C3034 at addr: 0xFFFFF240
read chip ID : 0x77082008 at addr: 0xFFFFF240
read chip ID : 0x46464646 at addr: 0xFFFFF240
read chip ID : 0x30343246 at addr: 0xFFFFF240
read chip ID : 0x2008342C at addr: 0xFFFFF240
read chip ID : 0x32464646 at addr: 0xFFFFF240
read chip ID : 0x30343246 at addr: 0xFFFFEE40
read chip ID : 0x2008342C at addr: 0xFFFFEE40
And the SAM-BA 2.8, return the fetal error about the mismatch processor id or similar.
What should I do? or please give some suggestion.
More information, after finished booting process, the STAT LED is blinking and the YELLOW LED is alway lit, it look like the board is normal running.
wsch. (I am very new on linux and ARM)
