sd card shield for leonardo
Hi, my UNO R3 sd card shield does not work with my leonardo, is there some way to fix this or do you have an sd card shield for a leonardo, using ide v102 thanks
You need to run jumper wires from the digital pins to the ICSP header. The SPI functionality is not connected to any digital pins on the Leonardo and is only accessible through the ICSP header.
