SEN-11084(Altimeter),SEN-12786(Accelerometer) coding to write to SD card help needed
Need help coding the two mentioned sensors to the DEV-13743 (SD card breakout). I am a noob so please bare with me. What is needed to get started in the right direction? I have all code from sparkfun and tried uploading it to Arduino mini pro and cannot get it to work. Need help coding it. Wiring is all good as I can upload individual segments of code and get good data. Please help and keep in mind I am super green at all this. Thank in advance both for your patience and help and most importantly your time.
Welcome to the software side of things!
Unfortunately, SparkFun’s Technical Support is unable to directly assist with writing custom code for projects. However, I would suggest looking at the following links to help you:
https://learn.sparkfun.com/tutorials/mp … duino-code
https://learn.sparkfun.com/tutorials/ad … okup-guide
https://learn.sparkfun.com/tutorials/mi … okup-guide
