send commands to gps
hi, i would like to configure to my Venus GPS logger (update rate), what can i do?
How can i send commnds to gps? thaks
The easiest way to do this is to get a 3.3v usb to serial adapter and uses SkyTraq’s software. I would go this route as it also allows you to tweak and turn on other settings. It is availiable on sparkfun on the venus module/ic produt pages…Sadly it only works for windows.
If you need to do this in your microcontroller, you will need to read the binary message data sheet for the venus IC.
thanks, how can i send to gps binary commands instead ? The skytraq datalogger software has few options.
Can you post the link of the skytraq software available on the sparkfun page ?
thanks a lot.
