I love this unit and work Very well. It work just like your tutor say it should. The Only problem I am having is the max out put is 100mw. (20 dbm) . You spec say it should go to 500mw. The firmware in the unit is 2.0
From the AT commands I can change the Power out put but Highest I can set is 100mw (20dbm) It should go to 27dbm but you get an error when you try anything above 20.
I am assuming we will need new firmware but there is no clear place I could find the proper Firmware.
Here the Dialog from the AT Commands
OK
RTI
RFD SiK 2.0 on HM-TRP
RTS4=27
ERROR
RTS4=20
OK
