Hello good people of SparkFun,
I recently upgraded to the serLCD with the Qwiic connection. It is great to be able to just plug and play.
However, I’m having trouble figuring out how to communicate with the ATmega328P over I2C with C code. I’m using wiringPi for the I2C communication. I can get the splash text to display on the serLCD with the following code.
int fd = wiringPiI2CSetup(0x72);
wiringPiI2CWriteReg8(fd, 0x7C, 0b00001000);
I think that code puts the serLCD into setting mode, which triggers the splash text.
I haven’t figured out how to display text yet. Has anyone figured this out?
Jarrod
Thanks for the reply! I am using that library.
I think I may have just been lucky that the wiringPiI2CWriteReg8 function worked for me. I’m now using wiringPiI2CWrite, and I can change settings and display text! I’ve copied some of that code below in case it helps anyone else. I think the next step is to write a function that takes a string and sends it to the display one character at a time.
// Open I2C connection to the serLCD
delayMicroseconds(500);
wiringPiI2CWrite(fd, 0x7C);
wiringPiI2CWrite(fd, 0x08); // software reset
delayMicroseconds(3000000); // needs more than 1 s to finish the reset
wiringPiI2CWrite(fd, 0x2D); // clear the serLCD
wiringPiI2CWrite(fd, 0x48); // display H
wiringPiI2CWrite(fd, 0x65); // display e
wiringPiI2CWrite(fd, 0x6C); // display l
wiringPiI2CWrite(fd, 0x6f); // display o
