Servo issue..
I have a redboard and Wrote code so that when i wave my hand in front of a ultrasonic sensor, the servo rotates.
It works fine with a a tiny servo, but when I use a hi torque servo, it doesn’t work.
I’m powering the servo separately. I know it’s getting enough power.
The servo doesn’t even act like it has power, no slight hitch when powered. But when I open the servo and power the leads on the motor directly, the motor spins.
This is my 3rd different servo.
What am I doing wrong ?
Can you provide photos and a schematic of your setup?
This may have damaged the control board inside the servo.
Newbie mistake. I didn’t use the same ground for the servo.
That’s what I was thinking, glad you figured it out!
