Rather than buy expensive presensitized copper - has anyone tried silk screening copper with etch resist ink? (silk screening appeals becuase I’m possibly going to be making a fair few boards - all the same)
Is it possible to get decent results with SOIC IC pad size tracks?
What mesh size would be best?
Anyone got some tips wrt the type of ink that I should be looking at? (Nazdar seem to do some etch resist ink, but I’m in the UK & can’t find any sources here - are there any other brands/ink types that will work?
If anyone is still interested I have many years of experience in the screen printing industry and have successfully made PCB’s at home with the screen printing process. I have even made double sided boards using dedicated feed through pads and jumpers for connections between sides. Using a 220 strand per inch mesh works well and allows a resolution more than good enough for between DIP pad traces. I haven’t made a board for surface mount components but I’m sure I could. The key is making sure the emulsion side of your film positive is the side that contacts the screen when it is exposed to prevent under cutting the image. While other methods are useful for making prototypes or small batches, the screen printing process can’t be beat for doing large runs of identical boards.
