SMA to MMCX converter?
Hi
Does anyone know where I can get a SMA male to MMCX female converter…I need to use a GSM antenna with a SMA male connection with my GM862-GPS which has a MMCX female connection.
Any ideas?
Dan
Digikey and Mouser both carry these.
Mouser P/N is 523-242121, Digikey is ACX1352. These are the same part from Amphenol-Connex, but Mouser’s pricing is a lot better. If these vendors are not convenient to use, try to find a distributor in your area that carries Amphenol/Amphenol-Connex connectors. The P/N you want is 242121.
I know the problem is resolved ,but I find the problem.
if your GSM antenna with SMA male ,so one end of converter is SMA female.
The connection of your GM862-GPS is MMCX female ,so the other end of the converter should be MMCX male .
So the adapteror pigtail SMA female to MMCX male will be needed to fit to your GM862-GPS with your antenna.
The adapter:http://www.rfsupplier.com/mmcx-adapter- … p-259.html
The pigtail :http://www.rfsupplier.com/mmcx-plug-jac … -1864.html
If anyone who would like to know the other kinds of rf adpaters or pigtails,you can contact me anytime.
Greetings !
