Soil Moisture Sensor Recommadations
My project focuses on comparing the accuracy of different soil moisture sensors. According to my current plan, I would prefer to insert each sensor directly into the soil and view the soil moisture reading immediately. Could you please advise which sensor(s) from your products would be most suitable for this purpose? Also, how can I access the soil moisture data from your sensors?
Thank you.
Any of these at the top (note 1 is discontinued). They differ slightly in how you access the data, but each has an associated hookup guide in its documentation section of the respective product page(s). Some are analog, some use i2c….you’d simply use the relevant protocol and voila
