I am looking for a solar charge controller to maintain a 7.4v li-ion battery pack (a connection to the panel, to the battery and to load). I found PRT-14411 in your website, but it seems to output 5v fixed. Is there any way I can get the same battery output (7.4v) from the controller, so that I can apply it to the load? I’m not sure if connecting the battery to the load will mess the charging algorithm of the controller. My load consists of a 5v MCU and a solenoid valve (here is where I need the 7.4v).
I also found PRT-12885, but it says it’s meant to be used with a single cell. My pack is 2S cells.
Do you have any suggestions for this?
