I have soldered plenty of 0.3mm pitch 100 pin LQFPs.
I find the best way is to first coat a pad or two with solder on the PCB. Then carefully using tweezers, place the IC onto the footprint, trying to line up all the pads. While doing this, I use a soldering iron to melt the little glob of solder I put in one corner previously.
When you think it’s lined up, let the solder solidify. At this point you can check to ensure it’s lined up properly. If it’s not you can try again. If it is lined up, I tack down the opposite corner with a bit of solder on a pin or two, being careful not to bump the package and bend pins.
From here, I just use the glob-of-solder method to run across an entire side at a time, then wick away the excess with solder-wick.
I hope that helps a bit… With a bit of patience and practice, it’s not hard at all.
Roko:
Cheers
Thanks for the quick reply. I’ve used the same technique. What I believe is that it works great for 64LQFP packages, but slight alignment errors seem to be amplified with 100-LQFP…
How do you ensure the tracks are not going to come off when melting the solder around the pads, if the initial alignment is wrong?
Roko:
0.3MM, that’s crazy. Never even heard of those.
I don’t have much trouble with 0.5mm LQFP’s though it does take a few adjustments and some time to get the alignment straight. Same technique, just do one point and adjust it a bit when it’s hot to get everything in place, then tack the other corner. I had a fairly tough time with 0.4mm LQFP, I don’t know how well I would do with 0.3mm.
It’s easier on professional boards. On home etched boards the leads tend to fall between the pads and get stuck so they don’t slide back and forth so easily.
