Hi there, I was following the instructions on how to setup a Sparkfun ESP8266 Thing Dev here: https://learn.sparkfun.com/tutorials/es … e-overview
But the instructions on how to connect a UFL antenna are too vague:
“If you need to connect a more sensitive antenna, or need to route outside an enclosure, a U.FL connector is also available on the board, but isn’t connected by default to the ESP8266’s antenna pin. To connect this antenna to the chip, you’ll need to swap the jumper by removing the solder blob and pushing it over to the other side.”
https://cdn.sparkfun.com/r/600-600/asse … 66-ufl.jpg
Would you be able to post a picture of the actual desoldering/soldering needed or annotate the picture above?
Thank you. ![]()
