SparkFun FM Tuner Evaluation Board - Si4703 WRL-12938 stopped working
I’m using your SparkFun FM Tuner Evaluation Board - Si4703. It was working so I decided to move it from my test setup to a permanent setup.
It didn’t work in the new setup so I moved it back to the test setup. But now it doesn’t work there either.
Any Ideas?
Also, troubleshooting SparkFun boards is difficult because a layout drawing showing where parts are located is not provided. For example, where on the board is capacitor C11?
Could you post a parts layout diagram?
Hello.
Can you post a few photos that clearly show your setup? What Arduino are you using?
Also, the parts layout is in the Eagle CAD files. All you need to do is download those off the ‘Documents’ tab on the [product page and use the [free version of Autodesk Eagle to view them.](Download EAGLE | Free Download | Autodesk)](SparkFun FM Tuner Evaluation Board - Si4703 - WRL-12938 - SparkFun Electronics)
