Hello
I purchased a SparkFun GPS-RTK-SMA Kit through your reseller in india on 28th Aug ( Buy KIT-18292 SparkFun GPS-RTK-SMA Kit | Evelta ) . While testing, i found that USB is not getting detected in windows or in linux.
I tried flashing your reset example through arduino, the flash goes well, but the module is still not getting detected. I also purchased a non kit module ( same model ) and its working fine.
I was told by the reseller that i need to get in touch with sparkfun and that they can authorize refund / return.
Please advice
I also tried connecting to windows via FTDI adapter ( using quick connect terminals, as i dont want to solder headers on a potentially faulty module ) . It connected fine. I also did software update. Still not working over usb
BTW - the cable is fine as it connects a separate module ( same model ) perfectly
I think you need to replacement.
yes, but i need a go ahead from sparkfun representative
Sparkfun is closed today as it is a national holiday in the USA. You should hear back from them tomorrow or the next day.
It does sound like a defective item (since you have a 2nd one working fine); contact Evelta for the replacement unit
Thanks @TS-Russell can you please email them ( just in case ) . I will dm you mine and their email addresses
