Hello!
For the SparkFun RGB Addressable CBI LED 5mm - Right Angle
[url https://www.sparkfun.com/products/23649
The photos show one of these devices installed on the board. And one LED installed in the black plastic body, and a final photo which is what the I am wondering about because it shows the PCB fully populated. Myself and one other are curious about that. Are these LEDs going to be sold separately?
I assume the last sentence has a typo (correct me if not!) and you mean ‘is the PCB going to be available to buy?’…no current plans (the one in the pic was a one-off that someone from engineering made)…but something similar can be made using these https://github.com/sparkfun/SparkFun_RG … n/Hardware
But! I will suggest to the Catalog team that the be added/available; I’ll circle back to this with an update if there becomes one
TS-Russell:
Hello!
Close,. I meant as a kit. The entire series of LED devices and the PCB. But your understanding is appropriate.
Now why is the Rockies Purple People Eater awake at that hour? He’s only working dawn and dusk hours.
