SparkFun Simultaneous RFID Reader - M6E Nano
Hello everyone
The first time I post here, hope I do it right,
I have an M6E and I can’t read through an external antenna, I’ve made all the necessary changes and I don’t get any data at all.
I would be very happy to help
https://i.ibb.co/jDXPdFP/Whats-App-Imag … -51-56.jpg
It looks you made the right change and normally that works.
Which external antenna do you use ?
Did you change anything to the sketch ?
Did it work before you made this change?
Does it work when you do NOT connect an external antenna and also make a short circuit to the on-board antenna ?
Do you have an ohm-meter and can you validate that the pin of the antenna connection is connected to the soldering pad you have made ?
