SparkFun Thing Plus ESP32-C6, unable to connect via Serial
I recently purchased two SparkFun Thing Plus - ESP32-C6 boards and I’m unable to connect to connect to either one using the Arduino IDE or Putty. They both power on fine when connected to USB-C and run the sketch that came flashed (RGB LED cycling through colors) but all of my attempts to flash with a different sketch or simply connect using Putty result in the following error:
'A device attached to the system is not functioning.'
I have other ESP32C6 dev boards that I can connect to without any problems, but both of my Sparkfun boards are unresponsive.
Does anyone have a suggestion on how to troubleshoot this?
You might try a different USB cable. A flakey cable can give that error message.
Yep, that was it. Thanks for the suggestion!
