SPX-14788 Documentation
We had purchased multiple SPX-14788 in approx. 2019. The product is no longer available on your website. I would like to find out what do I need to add / remove in order to use an external antenna instead of the onboard antenna, and where can I find / get hold of additional documentation?
Found a datasheet on Digi-Key that might be helpful.
The datasheet has links in for the schematic but I don’t know how long they will work. I attached a copy of the schematic as well.
Qwiic_LoRa_schematic.pdf (60.5 KB)
In the antenna / u.fl section of the schematic it tells you what resistors to swap to change from the internal antenna to the external antenna jack.
Here are the other links in that datasheet, you might want to grab them while they are still accessible.
Hope this helps!
Awesome! Thanks so much, I do appreciate it! :clap:
You’re very welcome!
Happy hacking!
