Hello dear, I share the following question with you to see if you can help us.
We would like to implement a project with some RFID products from Sparkfun. In order to make a validation test, we are trying to replicate the instructions detailed in the link https://learn.sparkfun.com/tutorials/si … 1514984116
We are using the followings products from Sparkfun:
Reader SEN-14066
Antenna WRL-14131
Tags WRL-14151
TNC to RP-SMA CAB-14132
RP-SMA to UFL WRL-00662
Arduino UNO
We have read the tags with the onboard antenna, but when we test with the external antenna the tags are not detected.
Please share with us an instructions set in order to test the external antenna isolated from the system, in order to validate separately if it is OK, and some recommendations to use it.
We look forward to your help.
