I received this board not too long ago, the board is not getting detected most of the time. I click on the Apple icon and go into About This Mac and then System Report. I refresh the USB Device Tree to see if the Hub is detected. I occasionally detected the Hub and I can plug in USB drive. The drive would show up in the Finder. I spent many hours trying different working cable that I have, the result is the same. The cables are from my Samsung T5/T7 SSD drive. I also tried on a Windows 10 machine and I also occasionally detected the Hub. Anyone encounter this issue?
Hi! Generally we aren’t able to provide much help with our experimental (‘SparkX’) products, but maybe try re-installing your USB drivers (and also USB-to-serial drivers) and see if that helps
Other than that, you could try closing the i2c jumper, putting the device into configuration mode, and seeing if changing some parameters there helps at all https://github.com/sparkfun/SparkFun_US … ration.ino - best of luck!
Is this product working for anybody successfully?
