you can find the details in the programming manual, but looking at the data… there is NOTHING wrong … no error messages. Maybe try to get some other tags to read like WRL-14147 or WRL-14151. I assume you had not removed the solder connection for the on-board antenna.
debugging the data you sent :
sendCommand: [FF] [00] [03] [1D] [0C]
THIS IS A REQUEST FOR THE PRODUCT INFORMATION
response: [FF] [00] [22] [04] [00]
Wrong opcode response
THIS IS AN CONSTANT READING INFORMATION THAT THERE IS NOTHING TO READ (set previously)
sendCommand: [FF] [03] [2F] [00] [00] [02] [5E] [86]
STOP CONSTANT READING
Time out 1: No response from module
Module continuously reading. Asking it to stop…
response: [FF] [14] [03] [00] [00] [14] [12] [08] [00] [30] [00] [00] [02] [20] [19] [06] [10] [01] [09] [01] [11] [00] [00] [00] [10]
THIS IS A GOOD RESPONDS FOR THE PRODUCT INFORMATION
sendCommand: [FF] [02] [93] [00] [05] [51] [7D]
THIS IS SET PROTOCOL (0X93) TO GEN2 (0X05)
response: [FF] [00] [93] [00] [00]
THIS IS A POSITIVE RESPONSE TO THE REQUEST
sendCommand: [FF] [02] [91] [01] [01] [70] [3B]
THIS IS SET ANTENNA (0X91) TO PORT 1 FOR READ AND WRITE
response: [FF] [00] [91] [00] [00]
sendCommand: [FF] [01] [97] [0D] [4B] [B0]
THIS IS SET REGION (0X97) TO NORTH AMERICA (0X0D)
response: [FF] [00] [97] [00] [00]
sendCommand: [FF] [02] [92] [01] [F4] [40] [AD]
SET THE READ POWER (0X92) TO 500 ( 0X01F4)
response: [FF] [00] [92] [00] [00]
Press a key to begin scanning for tags.
sendCommand: [FF] [03] [9A] [01] [0C] [00] [A3] [5D]
THIS IS OPTIONAL PARAMETERS (0X9A) , DISABLE READFILTER (0X0C00)
response: [FF] [00] [9A] [00] [00]
sendCommand: [FF] [10] [2F] [00] [00] [01] [22] [00] [00] [05] [07] [22] [10] [00] [1B] [03] [E8] [01] [FF] [DD] [2B]
THIS IS SENDING A REQUEST FOR EMBEDDED CONSTANT READING
response: [FF] [04] [2F] [00] [00] [01] [22] [00] [00]
NOTHING AVAILABLE TO READ
Scanning
Scanning
Scanning
Scanning
Scanning
Scanning
