Does anyone know if the SSOP to DIP Adapters will work ok for TSSOP parts? :?:
With out checking I don’t believe so. Do check the data sheet of the TSSOP parts you are using for the physical pin dimensions against a SSOP part.
You should be OK, but check the datasheets. I just looked at some datasheets for quad op amps, and the TSSOP and SSOP packages looked compatible. TSSOP can be a bit narrower, but as long as the pin pitch is 0.65mm, you should be OK.
