I am currently working on a development project in which I intend to use your SparkFun GPS-RTK-SMA Breakout - ZED-F9P (Qwiic).
For the mechanical design of my project, I require the STEP file (.step/.stp) of the breakout board. Would it be possible for you to provide it to me?
Thank you very much for your support.
Kind regards,
We have .brd and .sch files avilable here which you can import into KiCAD and then export them as STEP/STL/other
Thank you for providing the .brd and .sch files.
Unfortunately, when importing the board into KiCad and exporting it as STEP, I only obtain the bare PCB without the mounted components.
Would it be possible to provide a STEP model of the fully assembled board instead?
Thank you very much!
Hi @PrashathD ,
Do you need the STEP file to be exact, with all the correct component packages and LED positions? If not, then perhaps you could use the STEP file for the LG290P Breakout? It is almost the same…
