STM32 SWJ test
I success to enter into SWJ mode and read the SWJ_ID, but(signal after JTAG_TO_SWJ sequence):
http://www.simonqian.com/image/swj.jpg
Note Trn of STM32 is 0.
Any one know why?
Is there anything I missed?
8 more clocks should be driven low(IDLE clocks).
Another problem:
After enter into SWD mode and readout DPIDR, according to ADIv5.1.
In
int ahbap_debugport_init(swjdp_common_t *swjdp)
uint32_t idreg, romaddr, dummy;
uint32_t ctrlstat;
int cnt = 0;
int retval;
LOG_DEBUG(" ");
swjdp->apsel = 0;
swjdp->ap_csw_value = -1;
swjdp->ap_tar_value = -1;
swjdp->trans_mode = TRANS_MODE_ATOMIC;
dap_dp_read_reg(swjdp, &dummy, DP_CTRL_STAT); // returns 0x00000000
http://www.SimonQian.com/image/swj1.jpg
dap_dp_write_reg(swjdp, SSTICKYERR, DP_CTRL_STAT);
http://www.SimonQian.com/image/swj2.jpg
dap_dp_read_reg(swjdp, &dummy, DP_CTRL_STAT); // returns 0xC0000008
http://www.SimonQian.com/image/swj3.jpg
swjdp->dp_ctrl_stat = CDBGPWRUPREQ | CSYSPWRUPREQ;
dap_dp_write_reg(swjdp, swjdp->dp_ctrl_stat, DP_CTRL_STAT);
dap_dp_read_reg(swjdp, &ctrlstat, DP_CTRL_STAT); // returns 0x34000000
if ((retval = jtag_execute_queue()) != ERROR_OK)
return retval;
/* Check that we have debug power domains activated */
while (!(ctrlstat & CDBGPWRUPACK) && (cnt++ < 10)) // pass here
LOG_DEBUG(“swjdp: wait CDBGPWRUPACK”);
return retval;
alive_sleep(10);
while (!(ctrlstat & CSYSPWRUPACK) && (cnt++ < 10)) // CSYSPWRUPACK is never set
LOG_DEBUG(“swjdp: wait CSYSPWRUPACK”);
return retval;
alive_sleep(10);
dap_dp_read_reg(swjdp, &dummy, DP_CTRL_STAT); // read as 0x34000000
/* With debug power on we can activate OVERRUN checking */
swjdp->dp_ctrl_stat = CDBGPWRUPREQ | CSYSPWRUPREQ | CORUNDETECT;
dap_dp_read_reg(swjdp, &dummy, DP_CTRL_STAT); // read as 0x34000080
dap_ap_read_reg_u32(swjdp, 0xFC, &idreg); // SWJ fails here
dap_ap_read_reg_u32(swjdp, 0xF8, &romaddr);
LOG_DEBUG(“AHB-AP ID Register 0x%” PRIx32 “, Debug ROM Address 0x%” PRIx32 “”, idreg, romaddr);
return ERROR_OK;
In SWJ mode, to clear STIKYERR, STKERRCLR should be written to ABORT.
So in ahbap_debugport_init:
swjdp->apsel = 0;
if (dp_jtag)
else if (dp_swj)
dap_dp_write_reg(swjdp, STKERRCLR, DP_ABORT);
dap_dp_read_reg(swjdp, &dummy, DP_CTRL_STAT); // now return 0x00000000
swjdp->dp_ctrl_stat = CDBGPWRUPREQ | CSYSPWRUPREQ | CDBGRSTREQ; // without CDBGRSTREQ, CSYSPWRUPACK will be never set
dap_dp_read_reg(swjdp, &ctrlstat, DP_CTRL_STAT); // read as 0xF4000000
return retval;
return retval;
alive_sleep(10);
while (!(ctrlstat & CSYSPWRUPACK) && (cnt++ < 10)) // pass
return retval;
alive_sleep(10);
http://www.SimonQian.com/image/swj5.jpg
dap_dp_read_reg(swjdp, &dummy, DP_CTRL_STAT); // read as 0xF4000080, WDATAERR? How?
http://www.SimonQian.com/image/swj6.jpg
if I remove the code to enable CORUNDETECT, 2 dap_ap_read_reg_u32 will not fail, but all return 0. After read ap_reg, READOK will be set, but RDBUFF returns 0.
