Strange Aperture error
For some reason, the drcbot is reporting that I have an error on aperture 11 which are the pads of the IC I’m using. Strangely enough the pads are 10 mils wide, and each pad is spaced about 12 mils from each other. Could it be happening because the IC is placed at a 45 degree angle?
Artemis for Segger Studio 1V5.pdf (368 KB)
email me dcarne at this domain with your order name / email you used on batchpcb and I’ll see whats up.
Cheers,
–David Carne
