SW Maps does not connet to RTK2go clients
Hello everyone,
I have a Sparkfun RTK, and last year I was able to easily connect to RTK2go clients. However, today when I tried again, most of the clients did not connect, and some connected but then disconnected immediately. My friend has an RTK from another company, and he has successfully used a client called AkitaPrefUnivOgata from RTK2go since it is not included in the list of available software in SW Map.
You might need to refresh or get new credentials issued from rtk2go if it has been a while, not certain on their timeout procedure for login info…
Can you test your equipment with your friend’s info to eliminate some variables?
Thank you for your reply. Using the rtk2go does not need any login info (as you may know, the password is none). I used my friend login info but does not connect again. The data points that I have from last year are in mm accuracy but now only one RTK connect and it gives me 10 m accuracy!
How far away are the correction sources?
It is too far! I know it is not good but the only caster connects from rtk2go is this one! There are so many in my region, they are not in “get” list and not connected when I input mount name manually!
