NTRIP SW Maps
The NTRIP Client on SW Maps on Android for my SparkFun RTK Kit. I have created an account with PointOne, setup a device with model listed as ‘other’ with a location in North America. Then added the credentials to SW Maps ‘virtualrtk.pointonenav.com’, ‘POLARIS’, 2101 with my user name and password, version 1, and send check box selected. Yet, when I try to connect, it immediately fails. Do you have suggestions on possible issues and how to debug? I am connected to my rover RTK the entire time.
Do you see any error message?
I only receive a popup notification that ‘connection failed’
Can you try an alternate RTK caster service? rtk2go is free (can take 24 hours to receive the credentials though), or some other?
I don’t use PointOneNav. Is ‘POLARIS’ the mountpoint ?
If not, You will need to select a proper mountpoint.
Also, the Caster will need a valid position from your GNSS, so make sure it has a fix first.
