I’m using a facet gps with a iPhone and SW maps. Has worked fine in the past but when I opened it none of my previous setting were there so I made a new setup and everything seems right other than no rtk fix and the constant connect and disconnect of the NTRIP. Any ideas?
Welcome @Deereman23
In the NTRIP settings of SW Maps, make sure you’ve checked the Send NMEA GGA to Caster checkbox.
Maybe you have the incorrect Port #, or mount_point, etc ?
Try to spy on the Caster’s response, it might be telling you the error/problem ?
The gga was not checked and I think that fixed me. Thanks for the help
