SWARM M138 Connection
Hello, I would want to resolve the following question, ¿Can I connect the satellite module in his PCB with from USB 2.0 and external power supply on the same time? for example, such as show you the picture attached. It’s possible to do that and the modem can convey packets to Satellite.
Have a good day.
USB 2.0 is not supported for that board; but yes otherwise. See https://learn.sparkfun.com/tutorials/sp … akout-pins (the description for power circuitry is slightly above) and https://cdn.sparkfun.com/assets/1/a/7/c/8/Schematic.pdf
Too, Is posible to connect the PCB with the modem to a HUB with external power supply wit ports USB 2.0?
Regards.
Yes, that should work. The external power supply will deliver power to the modem - through the “ideal diode” circuit.
In this case, Can the device convey data to the satellite and see this information in Swarm Hive?
Yes, it should work.
