Hi guys
Im trying to send data from my EZ 10 module(has a GM 862 GPS chip) to a webserver for tracking purposes. I have read the Easy GPRS guide and hv a few problems.
I just want to know if the <PDP_addr> field for the AT command AT+CGDCONT when setting up my GPRS is for the IP addr of the telit module itself or of the terminal server Im sending to?
Secondly, if it is for the module, then does the addr “0.0.0.0” mean that an address will dynamically be assigned to the module when it sends data? Ive been through the AT command +CGDCONT and am a bit confused.
Once I’ve confirmed this then I can figure out why I’m not getting a response when actually accessing the netwrk with ATD99**.
Anybodys help is appreciated.
