Testing out the ZED-F9R Pi HAT
I’ve got a GPS-16475 I am trying to set up. I’ve followed the instructions from the Hookup guide but am getting no response.
The power LED is dimly lit on the board and the rest are unlit.
If I remove the board from the Raspberry Pi and connect it over USB-C to a computer to try and run uBlox u-center, nothing shows up on the computer and none of the LEDs light up.
I was wondering if there is any quick way to verify that the board is working.
Thanks.
The USB socket doesn’t supply power to the board, try putting the hat on a running Pi (to supply power) and connecting a USB-C data cable to the hat and a computer and see if you get a serial port showing up that way. If you don’t [fill in the form on this page with your order number and the URL to this post and we can help.](Return Policy - SparkFun Electronics)
