I wish to design and prototype a thin client computer with minimum computing, AI receptive, capable to get trained to decode data from the host, cheap (no raspberry pi). Any idea?
Unless you have piles of cash sitting around, you’re probably better off going with a Pi. Building a thin client from the ground up isn’t impossible, but it’s probably more work than a single person is going to be able to do on their own.
Yeah, it’s a Pi, but it works and it’s a proven design.
You want to design a computer and you are looking for cheaper than Pi. That’s funny. You should check out [Raspberry Pi 4(that’s the latest model), they are quite cheap in price and will do your task easily.
Even the LCD will cost more than the Pi board itself, so I don’t think you will find any better plateform/solution.](What is Raspberry Pi 4? Pinout, Specs, Projects & Datasheet - The Engineering Projects)
