I can’n use the S2 version with PlatformIO.
If I try : “board = esp32thing_plus”
I obtain during build : A fatal error occurred: This chip is ESP32-S2 not ESP32. Wrong --chip argument?
I tried to add “board_build.mcu = esp32s2” but it is worse.
Have you a working configuration file ?
It looks like that error happens when esptool.py passes esp32 instead of esp32-s2 https://www.esp32.com/viewtopic.php?t=18492
According to later posts updating to this https://github.com/lorol/arduino-esp32fs-plugin will correct the issue
Hope this helps!
ygageot
3
With Arduino IDE :
I install in the Preferences
https://raw.githubusercontent.com/espre … index.json
I can find your S2 board already defined
it works !
With PlatformIO :
I tried to build a configuration file but without success.
I need some help if somebody found a solution !
Did anyone get this working with Platformio?
