working with examples to learn use of board, copy and paste code into libre text editor,load file onto xbee using xctu, using micro python terminal after code wont run, hit reset and terminal tells me syntax error line 1, must have to modify copied code to make work, trying to auto run in blinky example, thanks
Huh?
You might be looking for our guide XBee3 Thing Plus Hookup Guide - SparkFun Learn (the REPL example is an LED blinking)
