I’m talking about the KR Sense Current and Voltage Sensor. I brought 3 of these sensors recently (90A variant) and all of them had the same issue:
The current reading (Analog I_out) would always show 0. I tried 5 Amps of max current but it still was 0.
The voltage reading (V_out) is fine. However, the I_out does not output any voltage even with voltmeters. I tried to measure the voltage drop across the shunt resistor and found the voltage to be 0V.
I’m certain there’s nothing wrong with my wiring. Since the same problem exists for all 3 of the sensors, I do believe that the sensor is the problem.
I think faulty products like this should not be on Sparkfun. Another user also had the same issue as with me: KR Sense Current and Voltage Sensor - 90A Not Working as Expected
I urge Sparkfun to take this matter into consideration.
