TM1650 Arduino library for 2 x 8 led display Post
Hey all I am using a 2 digit 8 segment [TM1650 Arduino library and I can’t seem to find the setting for that? I can only find TM1650_DISPMODE_4x8 and TM1650_DISPMODE_4x7. No 2x8.
My setup looks like this when running the code below:
https://i.stack.imgur.com/lWDEi.gif
My Arduino nano code:
#include <TM1650.h>
#include <BANNED.h>
//              [data Pin]
//              |  [clock Pin]
//              |  |  [num Digits]
//              |  |  |  [activate Display]
//              |  |  |  |     [intensity]
//              |  |  |  |     |  [display mode]
TM1650 display1(2, 3, 2, true, 7   );
void setup()
void loop()
   int n;
   for (n = 0; n < 10; n++)
      //                             [nNumber]
      //                             |  [byte bDots]
      display1.setDisplayToDecNumber(n, 0b0000);
      delay(250);
If someone could let me know how to go about modifying the code in order to allow me to use just 2 digitals instead of 4 then that would be great!](GitHub - maxint-rd/TM16xx: Arduino TM16xx library for LED & KEY and LED Matrix modules based on TM1638, TM1637, TM1640 and similar chips. Simply use print() on 7-segment and use Adafruit GFX on matrix.)
StealthRT:
Just to clarify, you're asking how to use two **digits** instead of 4 digits, correct?
