Hi!
Real quick … Im running the module with a regulator spec’d at 3.6V
the spec sheet claims max Voltage of 3.6V …has anyone had any
problems with this?
Tks,
mango4u
Hi!
problems with this?
Tks,
mango4u
mango4u:
Hi!Real quick … Im running the module with a regulator spec’d at 3.6V
problems with this?
Tks,
mango4u
You should use the correct voltage, the part might fail if a momentary increase in voltage occurs.
Leon
