Thanks for responding! Hereby the redboard code. The redboard recieves data from an Arduino Uno for tiggering the audio layers. The Arduino Uno is connected to GSR sensors.
#include <SparkFun_Tsunami_Qwiic.h> //http://librarymanager/All#SparkFun_Tsunami_Super_WAV_Trigger
#include <SoftwareSerial.h>
TsunamiQwiic tsunami;
const byte FADE_TIME_IN_SECONDS = 2;
const byte READ_PIN = 10;
const byte TRANSMIT_PIN = 12;
const int DECIBEL_OFF = -70; // an off sound
const int DECIBEL_ON = 10; // an on sound
bool tsunamiReady = true;
String command = “”;
SoftwareSerial fromSensors = SoftwareSerial(READ_PIN, TRANSMIT_PIN);
void setup() {
pinMode(READ_PIN, INPUT);
pinMode(TRANSMIT_PIN, OUTPUT);
fromSensors.begin(9600);
Serial.begin(57600);
Serial.println(“”);
Serial.println(“LOOK - Tsunami Controller”);
Wire.begin();
if (tsunami.begin() == false)
tsunamiReady = false;
Serial.println(“Tsunami Qwiic failed to respond.”);
stopAllTracksNow();
Serial.println(“LOOK - Tsunami Controller - Done setting up”);
void fadeInTrack(int which, long seconds) {
tsunami.trackFade(which, DECIBEL_ON, 1000*seconds, false);
void fadeOutTrack(int which, long seconds) {
tsunami.trackFade(which, DECIBEL_OFF, 1000*seconds, false);
void loop() {
if (fromSensors.available() > 0) {
int data = fromSensors.read();
if ( data != 13 && data != 10 ) {
char character = data;
command += character;
else if (data == 10)
Serial.println(command +" received");
// parse command
parseCommand(command); // so it can be changed again in between parsing time, if that would ever happen.
command = "";
void start()
stopAllTracksNow();
tsunami.trackLoad(a, b);
a = track nummer
b = output nummer
tsunami.trackLoad(1, 1); // voor gebruiker 1
tsunami.trackGain(1, 10);
tsunami.trackLoad(2, 1); // for STRESS
tsunami.trackGain(2, -70);
tsunami.trackLoad(3, 1); // for RELAXED
tsunami.trackGain(3, -70);
// Start playing them all at the same time.
tsunami.resumeAllInSync();
void parseCommand(String cmd)
int sepIdx = cmd.indexOf(“:”);
if ( sepIdx >= 0 ) {
String action = cmd.substring(0,sepIdx);
String data = cmd.substring(sepIdx+1);
int fadeIdx = data.indexOf("-");
long fadeTime = FADE_TIME_IN_SECONDS;
if ( fadeIdx > 0 ) {
fadeTime = data.substring(fadeIdx+1).toFloat();
Serial.print("Fade: ");
Serial.print(fadeTime);
Serial.print(", ");
data = data.substring(0,fadeIdx);
if ( action == "play" ) {
Serial.print("Playing track ");
Serial.println( data );
fadeInTrack( data.toInt(), fadeTime );
} else if ( action == "stop" ) {
Serial.print("Stopping track");
fadeOutTrack( data.toInt(), fadeTime );
} else if (action == "inout") {
int trackSep = data.indexOf("_");
if ( trackSep > 0) {
int trackToPlay = data.substring(0,trackSep).toInt();
int trackToStop = data.substring(trackSep+1).toInt();
fadeInTrack( trackToPlay, fadeTime );
fadeOutTrack( trackToStop, fadeTime );
Serial.print(trackToPlay);
Serial.print(", stopping track ");
Serial.println(trackToStop);
} else {
Serial.println("Wrong 'inout' input data");
} else {
Serial.println("");
} else {
if ( cmd == “reset” ) {
Serial.println(“Resetting”);
reset();
} else if ( cmd == “start”) {
Serial.println(“Starting experience”);
start();
void playTrack(int which) {
tsunami.trackPlayPoly(which, 0);
void reset()
stopAllTracksNow();
void stopTrackNow(int which) {
tsunami.trackStop(which);
void stopAllTracksNow() {
tsunami.stopAllTracks();
