Ublox zed f9p board hook up
L.S.
I am not a programmer and had some experience with VHDL (a long time ago).
How do i hook up the sarkfun ublox zed f9p to an arduino uno.
Need some guidance for this, the manual is not very clear about it.
TnX
Cees
https://learn.sparkfun.com/tutorials/gp … okup-guide
Probably the easiest way would be via Qwiic, you just need a [Qwiic shield for your Uno or you could use a [Qwiic breadboard jumper wire to connect 3.3 volts, ground, and the two I2C wires (SDA and SCL) on the Uno.
If you don’t already have an Uno, we make a Uno clone called the[ RedBoard Qwiic that’s the same as an Uno but adds a Qwiic port. You’d just need a [Qwiic cable to connect the two.](Qwiic Cable - 100mm - PRT-14427 - SparkFun Electronics)](SparkFun RedBoard Qwiic - DEV-15123 - SparkFun Electronics)](https://www.sparkfun.com/products/14425)](SparkFun Qwiic Shield for Arduino - DEV-14352 - SparkFun Electronics)
