ucLinux : Olimex SAM9L9260 or L9261 or is other board better
I’m hoping there’s people here that have already worked with Linux on the Olimex SAM9-L9260/61 boards or similar…
I’m planning to purchase the L9260, but would there be any good reason I might be better off buying the L9261 instead ??? (apart from WinCE or the LCD).
Or are there any ucLinux gurus here that think a different board is best to start learning, if so, which ???
I do need minimum SD/MMC (ideally 2), ethernet and serial.
I want to also use it to code a 802.11 sniffer for Ethereal based on SDIO WiFi card. (so I would need to boot off the 2nd SD if booting from SD is needed)
B rgds
Kris
