I just bought my first AVR setup, the parts listed in the title, and am having trouble getting it to program. I have the PG1B hooked into my serial port. Then the problems began -
The header on the end of the programmer has a red wire to indicate direction, but the board itself has no orientation indicator. Which way should it be plugged in? After plugging it in and applying power, one way has the board start up normally while the other prevents anything from happening. Which way is right?
Also, either way neither uisp nor avrdude will recognize the programmer. Each says that the programmer was not found. I have tried almost all the drivers avaliable, but none seemed to work. How do I download hex files?
I have searched extensively on the Internet, but could not find any information pertaining to either of these issues. Any help would be greatly appreciated!
Steven Schlansker
