I got a [ USB 32-Bit Whacker (DEV-09713) last year so I could try to prototype various projects, but I’ve had trouble doing anything with it.
I took some time today to try to follow the [ quick start on Brian Schmalz’s page, but instead of using the driver linked there, I downloaded the one from the product page.
I plugged my UBW32 into my laptop (running Windows 10) and the blue PWR led turned on.
Nothing came up for new devices, so I tried manually installing the UBW32 driver using PnPUtil. It seemed to work fine. Then I went to Device Manager and selected Action->Add Legacy Hardware. I went through the wizard:
download/file.php?mode=view&id=7200 download/file.php?mode=view&id=7199&sid … 2a422bc110
Now my board seems to appear under the “Ports (COM & LPT)” list as “USB Serial (UBW-based) communications port (COM4).”
Despite the Code 10 message pictured above at the end of the wizard and also in the device’s properties, I tried setting up a serial connection in PuTTY. I turned off flow control, used 9600 baud, 8 bits, 1 stop bit. When I try to connect I get this message and PuTTY quits:
download/file.php?mode=view&id=7201&sid … 2a422bc110
I’ve tried different USB ports and USB cables.
I’ve tried installing the driver from Brian Schmalz’s site and it wouldn’t install.
I have a PICKIT 4 but I don’t really know how to use it.
Any tips on how to get this working would be great.](UBW (USB Bit Whacker) Project)](https://www.sparkfun.com/products/9713)
