Unusual shaped pad in Eagle
I am using Eagle PCB Layout.
I wish to make a footprint for the inductor SRR6028-100Y (Bourns).
****Bourns inductor datasheet
http://www.bourns.com/pdfs/SRR6028.pdf
However, as you can see from the datasheet, the pads need crescent shapes in them,
Do you know how I can get such shapes into the pads?
You will have to draw the pad, the stop mask and the cream layers manually using the line, radius and arc tool.
