USB power meter (TOL-15571)
Does anyone know if the TOL-15571 supports any kind of data reading, or is the recorded data only available on the screen? I have tried to see, if the device is recognized as a serial device by Matlab, but no luck.
USB Power Meter (Color TFT LCD) - TOL-15571 - SparkFun Electronics
Here it says "In addition to the main numeric measurement interface, you can also toggle to voltage and current bar graph interfaces (because who doesn’t like a good graph?), quick charge identification mode, wire group impedance measurement, and a simple settings screen. And with the recording option, you can easily record your data. "
Share a method if you figure one out; I can’t get anything useful to happen
