Use xbee to read hardware version of end device?
I am new to zigbee and want to know if any knows how i would read ther hardware version of a zigbee device?
In the Digi manual, “Sending ZigBee Cluster Library (ZCL) Commands with the API” it shows me the command to use to achieve the result but am a bit confused on how to do this?
Is there any mailing list etc specilaisinh in xbee/zigbee discussion?
thanks in Advance
Digi International has a user forum.
And their tech support by phone is usually good.
did you get this command to work?
Is use this command
Send:(17:40:13) 7E 00 14 11 01 C8 D2 C1 00 00 00 1D BC FF FE 0A 0A 00 00 01 04 00 00 A3
C8 D2 C1 00 00 00 1D BC is the device address
01 04 Profile ie Home Automation Profile
