Venus GPS + 10Hz + Binary Protocol ?
I currently use the VENUS634FLPx GPS receiver and communicate with the binary protocol. I’m having issues with 10Hz update rate. I’m able to configure the chip to update the GPS position at 10Hz and it’s possible to see that data coming at 10Hz when using the NMEA protocol. Bu t the binary protocol seems to support only 1Hz?
CONFIGURE NAVIGATION MESSAGE INTERVAL has the unit in seconds… I tried to submit that command to see how it behaves and the problem is that that command is always NACKed by the chip ;/
Do you have any experience with that?
thanks,
tomek
